jmax007 Posted June 1, 2010 Report Posted June 1, 2010 I am using the "open VI reference" to call a vi like a pop-up window. like shown: In the vi that I am calling, "Debug_Output_Display.vi" I am connecting to a com port. I would like to be able to specify which COM port to choose. This is all part of a much bigger program that has one front panel where the COM port is selected. How can I pass this information to the "Debug_Output_Display.vi"? I am not sure how to do this? Any help would be appreciated. Thanks Jamie Quote
Francois Normandin Posted June 1, 2010 Report Posted June 1, 2010 How can I pass this information to the "Debug_Output_Display.vi"? Hi Jamie, Among other things, I'd suggest initializing a functional global variable with the COM port value you want in your main program, and then access it from your dynamically called VI. You could also use the "Control Value: Set" method (VI Server) but that doesn't scale well since it's a methodcalled by label text... Change the label text in a future version of "Debug_Output_Display.vi" and you break your functionality without any way to trace it with a broken arrow. Quote
jmax007 Posted June 1, 2010 Author Report Posted June 1, 2010 Thanks. That will work perfectly. Not sure how I missed this? I guess I'll mark this as the new thing I learned today:) Quote
PaulG. Posted June 2, 2010 Report Posted June 2, 2010 (edited) I used to use invoke node Ctrl Val.Set but Francios' warning about it not scaling well makes a lot of sense. I would lean more towards the functional global. Edited June 2, 2010 by PaulG. Quote
