Spectrum using FFT
i am trying to convert a time-signal to a frequency signal using FFT Spectrum (Mag-Phase).vi. As the frequency expected is in the Terahertz range (10^15 Hz) and the frequency range is very smallband, I need a good resolution in the frequency range, but as the Labview output starts at 0 Hz, it's not very well resolved. So I need a way to increase the resolution (i. e. decrease the df of my output signal), but I don't know how to do this...can somebody help me?
thanks in advance,
christian
Yep, the way to increase resolution is to take more data. Here's an article explaining that:
http://zone.ni.com/devzone/cda/tut/p/id/4278
The tough part for you is the frequency of interest. If you're really in the terahertz range, which is actually 10^12, to satisfy Nyquist you'll need to be sampling at least twice your frequency. For a df of 0.5 Hz, that 2 seconds of sampling is going to be terabytes worth of data. That's a lot of numbers. You'll have to make some good decisions about exactly what df you need and if you have the hardware to handle that much.
Extend your time sample if you are just looking to increase the df (df ~ 1/T where T is the time length). You may want to look at a Zoom FFT in the Sound & Vibraion Measurement Suite if you are only looking at a small portion of the frequency range.
Tim
