Dr Tallman Posted June 4, 2010 Report Posted June 4, 2010 Is there a straightforward way to establish direct communication between two computers (WiFi or bluetooth) allowing a vi on one machine to control a vi on the other? I need to establish this capability in places without internet access. Thanks. Richard Tallman Quote
crelf Posted June 4, 2010 Report Posted June 4, 2010 When you say "without internet", can the both have ethernet cards that are linked? How about RS-232 (NI-VISA is really easy to use)? Or do you specifically need wireless? What sort of data are you transmitting? Rates/amounts? Quote
Dr Tallman Posted June 4, 2010 Author Report Posted June 4, 2010 An RS-232 option would be acceptable but I really did want to have a completely wireless option. A little background. I have developed a patient simulator designed to work with a heartlung machine. It consists of a series of reservoir bags, tubing etc. and pressure and flow sensors connected via A/D. A heartlung machine attaches to the simulator and when bypass is initiated, the simulator mimics a patients response. The simulator output is the monitor (1.jpg). Also, running seperately is a VI that the "instructor" is running (2.jpg). This VI is used to keep track and evaluate the "student" running the heart lung machine. This second VI is designed to work on a tablet and uses handwriting recognition to input comments. My plan is to use the "Instructors" VI to change certain controls on the Simulator. Sliders, booleans etc. Both of the computers I used have WiFi but I don't want to use any external network. Thanks for your Help. Richard Quote
Ton Plomp Posted June 11, 2010 Report Posted June 11, 2010 On 6/10/2010 at 9:03 PM, crelf said: Maybe use a wifi bridge/access point? You should set up an Ad-hoc network. In windows you can select your Wifi software to only connect to access points (default), change this to Ad-hoc networks. Note that you don't have a DNS so you need to set your IP addresses yourself. I think you can use a similar technique for bluetooth. Ton Quote
