JKI RCF plugins all have duplicate menu items
Why do all of my JKI RCF plugins have duplicate menu items? For instance the Insert Type Conversion plugin has two identical menu items- Insert Conversion Node. The first line works as expected. The second one deletes the wire. A few other ones do similar bad things with the second entry. Others will do the same thing for both entries. What's going on?
George
George
This is probably because in the option window you pointed the "plugin development source dir" to the installed plugin location (hence resulting in 2 instance of each plugin). This should point only to your source plugin dir (the one you are working on). This dir (plugin development source dir) is typically different than the installed dir (and should remain empty if you don't have source plugin).
PJM
