Built exe shows two icons on task bar when launched
Hello there,
I have a weird problem with a very simple exe that I've built.
As you can see in the attached image, when I launch the application (which happens correctly) two icons show up on the task bar. Does anyone know whey this happens please?
Thank you,
Martin
Hello there,
Thank you,
Martin
Hi Martin
(There is no image attached)
I have seen this before but not with LV2009 - what version of LV are you using?
Place the following in the .exe's ini file: HideRootWindow=True
This fixed it for me (LV 8.5.1 I think)
Cheers
-JG
Hi Martin
Cheers
-JG
Great, thank you I will try that and see how I get on - thank you for the help. I do have LV2009. It seems intermittent as it did it this morning and then not this afternoon although I didn't do a rebuild.
Cheers,
Martin
