Curve fitting a hand drawn picture
Hello,
I have a pretty simple program with a picture control on the front-panel on which I want to be able to draw a wave.
I already came this far tongue.gif.
Next I want to have some kind of function which uses the picture and generates a waveform which can be generated by the DAQ hardware.
Does anyone know if this is possible and how?
attached is what I came up with this far.
main.vi
Link to post
 It's possible, but you'd have to validate the drawing's data before you could make it into a waveform.  I've made it into an X-Y Graph by doing this:
What would your waveform look like if you moved your pen from right-to-left?  That's one thing you'd need to handle.
Interesting question, however.  What's your application going to do?
main.vi (LV 8.2)
Link to post
main.vi (LV 8.2)
thanks for you reply.
I want to make a program where you can draw a waveform which can be later on be generated by my DAQ analog out.
Link to post
I understood that part, I just don't understand why.
I've modified my earlier example to use the Waveform data type, but you'll see that it doesn't faithfully represent what's been drawn.  This is where you'll have to define how to convert X-Y data into a waveform (axis scaling and handling right-to-left pen movement, to start).  Do you understand what I mean?
main (1).vi
Link to post
Thanks again for you reaction.
I have been tuning my software and also added code to scale/sort x- and y-axis.
My waveform is now almost a duplicate of the drawing.
There is however a bug which I haven't found jet which screws up my x-axis scaling.
I'll try to fix this myself. Thanks for all the help so far.
Link to post
