Dynamically adjusting position and size of front panel elements
Hi all,
I have a front panel with maximum 10 indicators. I can select how many indicators to be displayed in the front panel. So no. of front panel elements may vary from 1 to 10. I am having a fixed space in the front panel to accomodate all these indicators. What I need is, if I select for 2 indicators, size and position of these indicators should automatically adjust to accomodate in the given space. That is, if no.of indicators is less, size of indicators should increase accordingly, and if more no.of indicators selected, size of indicators should decrease accordingly. Position of the indicators also need to change inorder to make the front panel neat.
Is it possible? Thanks in advance.
Suvin
Hi all,
Suvin
Here's a little toolkit that has the option to 'align and distribute' rectangles, and can be used for your solution.
It does not deal with resizing, but when you figured out the new size, the 'distribute' function will return the new positions of the control on request.
Here's a little demo for this:
And a little video:
<object id="scPlayer" class="embeddedObject" width="630" height="547" type="application/x-shockwave-flash" data="http://content.screencast.com/users/TonPlomp/folders/Jing/media/b7173873-b25e-4506-96a3-c27f2c0bae48/jingswfplayer.swf" > <param name="movie" value="http://content.screencast.com/users/TonPlomp/folders/Jing/media/b7173873-b25e-4506-96a3-c27f2c0bae48/jingswfplayer.swf" /> <param name="quality" value="high" /> <param name="bgcolor" value="#FFFFFF" /> <param name="flashVars" value="thumb=http://content.screencast.com/users/TonPlomp/folders/Jing/media/b7173873-b25e-4506-96a3-c27f2c0bae48/FirstFrame.jpg&containerwidth=630&containerheight=547&content=http://content.screencast.com/users/TonPlomp/folders/Jing/media/b7173873-b25e-4506-96a3-c27f2c0bae48/Distribute.swf&blurover=false" /> <param name="allowFullScreen" value="true" /> <param name="scale" value="showall" /> <param name="allowScriptAccess" value="always" /> <param name="base" value="http://content.screencast.com/users/TonPlomp/folders/Jing/media/b7173873-b25e-4506-96a3-c27f2c0bae48/" /> </object>
Good luck,
Hi Ton,
Thank you so much for the reply. But I am using LV 8.6 I couldn't open your vi's. Any possibility to get vi s in LV 8.6?
Thanks in advance,
Suvin
Hi Suvin, I've saved the snipped for LV86. Distribute.vi
There is also the Object_distribution package for OpenG attached (also for 8.6) Object_distribution_86-1.2-0.ogp
I suppose you are already using JKI VIPM.
Greetings, LogMAN
Edit: sorry, VI was broken - now it's fine.
Edited by LogMAN
