mike5 Posted July 28, 2010 Report Share Posted July 28, 2010 (edited) I have this external library that works on Windows and Linux, providing DLL for Windows and .so for Linux. I had to move files around a bit, and got a few broken dependencies as a result. I was able to relink all the DLL calls, but when I try to do the same for .so calls, the LabView complains that it cannot process the library. Is there any way to do this on Windows, or do I have to use LabView on Linux to do this? Br, Mike Edited July 28, 2010 by mike5 Quote Link to comment
Ton Plomp Posted July 28, 2010 Report Share Posted July 28, 2010 I have this external library that works on Windows and Linux, providing DLL for Windows and .so for Linux. I had to move files around a bit, and got a few broken dependencies as a result. I was able to relink all the DLL calls, but when I try to do the same for .so calls, the LabView complains that it cannot process the library. Is there any way to do this on Windows, or do I have to use LabView on Linux to do this? Br, Mike Make sure the .so file is in the same path as the .dll (so only the extension differ), and relink your calls to mydll.*, this should do the trick for Linux as well. Note that Linus is case-sensitive. Ton Quote Link to comment
mike5 Posted July 28, 2010 Author Report Share Posted July 28, 2010 Make sure the .so file is in the same path as the .dll (so only the extension differ), and relink your calls to mydll.*, this should do the trick for Linux as well. Note that Linus is case-sensitive. Ton So, in the "Conditional disable" I relink the "Linux" case to the dll, and I am done? How about the calling convention? Windows or C? I guess C, but I want to be sure. Thanks and best regards, Mike Quote Link to comment
Ton Plomp Posted July 28, 2010 Report Share Posted July 28, 2010 So, in the "Conditional disable" I relink the "Linux" case to the dll, and I am done? How about the calling convention? Windows or C? I guess C, but I want to be sure. Thanks and best regards, Mike I'm not sure about the calling convention, but you don't need a linux specific case. Look at the NI DAQmx VIs where they are linked to daqmx.* On each platform LabVIEW selects which file to load. Ton Quote Link to comment
Rolf Kalbermatter Posted August 3, 2010 Report Share Posted August 3, 2010 So, in the "Conditional disable" I relink the "Linux" case to the dll, and I am done? How about the calling convention? Windows or C? I guess C, but I want to be sure. Thanks and best regards, Mike No Ton already mentioned it although didn't say so specifically. For the libraryname you enter <name>.* and make sure that the .DLL and .so are in the same directory on the respective platform (they can be both present on both platforms but don't need to be). Then LabVIEW will replace the * at the end with whatever prefered shared library extension for that platform and load the resulting library. Quote Link to comment
