Ton Plomp Posted August 12, 2010 Report Posted August 12, 2010 I'm going to start a Real Time (Crio) project and it's been a while since I've been there. Last time was 5 years ago. It's an old controller and I am wondering if a how a State Machine will perform on that platform? Or any other recommandations? Ton Quote
viSci Posted August 12, 2010 Report Posted August 12, 2010 LVRT even on an older cRIO should provide plenty of cpu bandwidth for simple constructs such as a state machine or timed loops etc. The things that can really eat up cpu is the scan engine and the use of network shared variables. BTW, the distributed system manager will give you a readout of cpu% and memory usage so you can easily run some preliminary tests. Quote
Wire Warrior Posted August 16, 2010 Report Posted August 16, 2010 I built a system on a sbRIO (basically a unpackaged cRIO) earlier this year that used a state machine no problem. Matter of I used a modified version of the JKI state machine for the basis for the code. Not having a front panel meant some of the open close VI code was not needed. Based on my experiences you should have no issues building a state machine based architecture on an RT system. Jason Quote
