Use of Variant causes Excel not to close
I've got a program that converts Excel worksheets into 2D arrays of strings.
I'm having a problem where Excel does not close if I use the 2D array for anything.
post-18058-039896600 1282763708_thumb.jp
If I do not use the array, Excel closes fine.
post-18058-094061200 1282763701_thumb.jp
I've attached Labview 8.6 files of both the working and nonworking versions. It would be great if someone can tell me what I've missed here. Suggestions for simpler ways to do this are also welcome, as I'm a little new at ActiveX.
Thanks!
Excel Test Works.vi
Excel Test Fails.vi
Edited by Random User
It seams that you have a type mismatch here. I have not noticed this behavior before, but LabVIEW ignores the conversion if no output is wired. If a scaler (single string) is wired to the type input of the "variant to data" function, there are no errors. This could be caused because there is no data on the variant "value2". I usually use the report generation tool kit. It has functions for this kinda of work.
Mike
  • Like 2
Right - you're trying to read a single Excel cell into a 2 dimensional array - that's not going to work. Also, I'm guessing that there's an error on the error cluster after the convert to variant VI, which might be causing something downstream (prbably the Workbook|Close method) to not execute - that's why Excel isn't closing. I suggest you rearchitect your code a little to use the merge errors VI, instead of chaining all the errors into one wire.
Ok, you guys have helped me figure this out. What I'm doing works in the general case since I'm converting a range of cells to an array of strings (instead of a single cell to an array). But it's true that one of the worksheets in my workbook causes a type mismatch...must be some cell with a weird format or something. Removing that particular worksheet allows my program to run normally.
Thanks!
