jgcode Posted September 6, 2010 Report Share Posted September 6, 2010 Anyone else getting this popup in VIPM at the mo? JKI Support forums are down for upgrades - don't know if it is related or not? Cheers -JG Quote Link to comment
Mellroth Posted September 6, 2010 Report Share Posted September 6, 2010 Anyone else getting this popup in VIPM at the mo? JKI Support forums are down for upgrades - don't know if it is related or not? Cheers -JG I have no problem opening VIPM at the moment. When do you get the popup, at startup or...? /J 1 Quote Link to comment
jgcode Posted September 6, 2010 Author Report Share Posted September 6, 2010 I have no problem opening VIPM at the moment. When do you get the popup, at startup or...? /J Was at startup. All good now? (which is good) Thanks for checking Quote Link to comment
crelf Posted September 7, 2010 Report Share Posted September 7, 2010 I talked to Jervin: NI had let their package repository license expire so the LabVIEW Tools Network was down for a short while - should be all good now. 1 Quote Link to comment
jgcode Posted September 7, 2010 Author Report Share Posted September 7, 2010 I talked to Jervin: NI had let their package repository license expire so the LabVIEW Tools Network was down for a short while - should be all good now. Ok, cheers, musta got unlucky (bad timing). Quote Link to comment
Jim Kring Posted September 7, 2010 Report Share Posted September 7, 2010 NI created their repository using VIPM 2010 Beta, which expired after the beta period ended. We noticed the issue and fixed it right away -- it's all good, now. I'm glad to see you're hard at work using VIPM on the weekends, Jon Quote Link to comment
