Scrolling Option in listbox
Tan_godo
Hi there ,
I require to have a vertical scroll option in listbox . The property node "Visible Items-> Vertical scroll bar " makes the scroll bar visible but the scroll position should change according to the data added in the listbox . In a string control setting "Scroll Position" is possible but in case of " listbox " i am not able to get the vertical scroll bar to show the last updated data.
Regards
Tan_godo
The listbox has a property called Top Row which allows you to control this. If you want the last element to appear at the bottom of the listbox, you'll need to calculate what the top row needs to be using the size of the listbox and the size of each row.
Ok .....
Thanks . I'll try that out ...
Please upload an example of your issue - it's a lot easier to make suggestions when we know what we're dealing with.
