Bobillier Posted September 16, 2010 Report Posted September 16, 2010 Name: Convert-To Submitter: Bobillier Submitted: 16 Sep 2010 File Updated: 15 Jun 2011 Category: JKI Right-Click Framework Plugins LabVIEW Version: 8.5 License Type: BSD (Most common) Convert_to v1.1.0 LV8.5 Copyright © 2010, BOBILLIER ERIC All rights reserved. Author: BOBILLIER ERIC LAVA Name: BOBILLIER ERIC Contact Info: Contact via PM on lavag.org LabVIEW Versions: 8.5 Dependencies: Nones Description: This tool is a right click framework plug_in. it's use to convert one or few elements ( control or constant) in one cluster. You can convert one element ( control or constant) in array. (if this element is one array, then add one dimension). You can convert too one array or cluster in this element(s). And that without moving anythings. Installation and instructions: This tool is package in .ogpb file. Please use VIPM for installation. Examples of use: http://www.screencast.com/t/NTk4MzY0Y Known Issues: Acknowledgements: To Dan_K for the start idea (http://decibel.ni.co.../docs/DOC-10621) Version History: v1.0.0: Initial release of the code. v1.1.0: Terminal and constant are correctly place in structures if need. License: Copyright © 2010, Eric BOBILLIER All rights reserved.Redistribution and use in source and binary forms, with or withoutmodification, are permitted provided that the following conditions are met: 1. Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer. 2. Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. 3. All advertising materials mentioning features or use of this software must display the following acknowledgement: This product includes software developed by the INRA. 4. Neither the name of the INRA nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission.THIS SOFTWARE IS PROVIDED BY Eric BOBILLIER ''AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIEDWARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE AREDISCLAIMED. IN NO EVENT SHALL Eric BOBILLIER BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THISSOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. Support: If you have any problems with this code or want to suggest features: please go to lavag.org and Navigate to LAVA > Resources > Code Repository (Certified) and search for the "Convert-to" support page. Distribution: This code was downloaded from the LAVA Code Repository found at lavag.org Click here to download this file 1 Quote
Mark Balla Posted September 19, 2010 Report Posted September 19, 2010 Certified 9-18-2010 Placed in the JKI RCF category. Quote
