sydney Posted September 20, 2010 Report Posted September 20, 2010 I have Full Development System 2009 that I have been using along with a Windows version and just noticed that I do not seem to be able to use the TDMS library in the Linux version since it is not there! Are there any plans to add this in the near future? Quote
Adam Kemp Posted September 20, 2010 Report Posted September 20, 2010 I have Full Development System 2009 that I have been using along with a Windows version and just noticed that I do not seem to be able to use the TDMS library in the Linux version since it is not there! Are there any plans to add this in the near future? We can't comment on what will or will not be in future versions of LabVIEW. If a feature or improvement is important to you then I suggest you use the LabVIEW Idea Exchange to raise awareness. We use that quite a bit these days to measure support for features. Quote
Phillip Brooks Posted September 20, 2010 Report Posted September 20, 2010 If you need to store your data in a hierarchical format, you could look into HDF5. I believe there are LabVIEW libraries for this, and they should be compatible with Windows and Linux. A suggestion for HDF5 has already been placed on the Idea Exchange: Suggest that LabVIEW support HDF5 Quote
Ton Plomp Posted September 21, 2010 Report Posted September 21, 2010 Here's a is a limited API for TDMS in Linux, mac and RT. Ton Quote
