John Lokanis Posted September 20, 2010 Report Posted September 20, 2010 It appears that the font used by system controls has changed between XP and Win7. As a result, some character graphics (progress bars using ||||||||) that I used in tables and MCLB system controls no long fit the same. Does anyone know of a way to fix this? Di you even know what the font (and size) was in XP and is in Win7? I poked around but could not find it. Sure wish we could embed data types and controls other than string in a MCLB or table. thanks for any suggestions. -John Quote
jgcode Posted September 21, 2010 Report Posted September 21, 2010 On 9/20/2010 at 11:19 PM, John Lokanis said: It appears that the font used by system controls has changed between XP and Win7. As a result, some character graphics (progress bars using ||||||||) that I used in tables and MCLB system controls no long fit the same. Does anyone know of a way to fix this? Di you even know what the font (and size) was in XP and is in Win7? I poked around but could not find it. Sure wish we could embed data types and controls other than string in a MCLB or table. thanks for any suggestions. -John Some of my GUI got severely messed up when they were compiled n XP but were run buy the client in Win7. I found it easier to switch to compiling in Win7. Quote
zobert Posted September 21, 2010 Report Posted September 21, 2010 Since Win2K I have been adding following to application ini files to "fix" my fonts. These match what I have set development environment to use for fonts. MyApplication.ini [MyApplication] FPFont="Arial 14" appFont="Arial 14" dialogFont="Arial 14" systemFont="Arial 14" BDFont="Arial 14" Default Windows System Font. NT4 - MS Sans Serif 2K/XP - Tahoma Vista/7 - Segoe UI 2 Quote
John Lokanis Posted September 21, 2010 Author Report Posted September 21, 2010 I have alway set these in my INI file: appFont="0" 13 dialogFont="2" 13 systemFont="1" 13 HideRootWindow=True blinkBG=000000FF thanks for the font info. I guess I will need to find a way to detect the OS and go from there. 2 Quote
SuperS_5 Posted September 21, 2010 Report Posted September 21, 2010 Thanks, using these settings in the LabVIEW environment helped me a lot. I will also be adding these to my program ini files as well. I totally forgot about these settings, I was starting to hate the "windows classic" theme. Mike Quote
zobert Posted September 23, 2010 Report Posted September 23, 2010 On 9/21/2010 at 6:21 PM, John Lokanis said: I have alway set these in my INI file: appFont="0" 13 dialogFont="2" 13 systemFont="1" 13 HideRootWindow=True blinkBG=000000FF thanks for the font info. I guess I will need to find a way to detect the OS and go from there. So far Microsoft has kept Arial in all the OS versions and this is the reason I have decided to use this as my standard font for all functions. I even make these my defaults in the labview.ini file for the IDE. Quote
PaulL Posted September 28, 2010 Report Posted September 28, 2010 On 9/23/2010 at 12:31 AM, zobert said: So far Microsoft has kept Arial in all the OS versions and this is the reason I have decided to use this as my standard font for all functions. I even make these my defaults in the labview.ini file for the IDE. Thanks to you both for this exceptionally helpful information! We struggled with this a while back and then pushed off the resolution to a later date. This gives us a workable solution! Reputation points coming your way! A couple things I observed: In zobert's 20Sept post I think the quotation marks should enclose just the font name, not the size. Anyway, it seemed only to work for me the one way. I found that if I changed the .ini file for a built application (.exe) I had to recreate any shortcuts. (If I just ran the application from the existing shortcut the changes to the .ini file were not applied.) In practice, I expect that won't happen often, but when I was trying to follow what you all were suggesting I ran into this and found it quite confusing. (Nothing I changed in the file made a difference!) Thanks much! Quote
