Thang Nguyen Posted October 1, 2010 Report Posted October 1, 2010 (edited) Hi, I am working on a project which I build a plant model in Matlab/Simscape and control this plant from Simulation Interface Toolkit (SIT). The issue I am having right now is timing. Time in LabVIEW is faster than in Simulink. So if I open a valve for a duration of time in LabVIEW, it will happens faster than it should be in Simulink. I tried to get the time in Simulink and used that as the time to measure the duration and now it slower than it should be. Do you have any experience with this? Could you please give me some recommendation for this issue? Thank you so much for your time! Best regards, Thang Nguyen Edited October 1, 2010 by Thang Nguyen Quote
