How to get file path?
Hello everyone,
Please take a look at the enclosed image. How could I get the file path value in case "True"?
(Case "True" description: there is no path input to "Read from Text file", a dialog box will pop up for selecting file. I want to get the path value and pass it back to the file path control on front panel. )
Thanks in advance
post-17688-038556700 1287066290_thumb.pn
Hello everyone,
Thanks in advance
You might consider using the function "Check if File or Folder Exists" instead. The path may not be empty, but that doesn't mean the file exists.
Use the file or folder exists? output to control your case statement and use the dup path for the read file function.
If you use the Close File function, the output is the path to the file.
Yes, that's it. Thanks. How could I ignored "close file" :frusty:
Thanks. "Check if File or Folder Exists" does avoide the VI to open unexist file, but it couldn't deal with empty path. So I combied both "Check if File or Folder Exists" and "Empty string or path".
Edited by Mars Su
