[CR] MemBlock
I had a situation where I needed something like this, however, I found a good G code solution. I had a dll call that would spawn a new thread, and return immediately. The spawned process would continuously put data into an array that was provided to the dll by LV. The problem was that LV would de-allocate/reallocate the array memory space after the subVI calling the dll completed. This of course causes memory corruption problems. The solution was to use an uninitialized shifter for the array, prefilled to the desired array size. This allows the memory space to remain open, and no corruption errors.
  • 2 weeks later...
To make things clear - These functions ARE pure G code. Although they use Call External Function Node, as library path they use "LabVIEW" keyword - so they should work regardless of operating system. Of course there is question of "pureness" definition...
  • 4 weeks later...
