Avoid Record duplication in MYSQL Server
Hi All,
I am using MySql server as my backend for current project. I need to store around five records per second to my database. Is there any way to check for duplicate record present in the databse while inserting the data? Retrieving the complete data and checking it with current record is not a good solution all the time I guess.
Thanks in advance,
Suvin.
Hi All,
Thanks in advance,
Suvin.
You can use "REPLACE" which will "INSERT" if it doesn't exist or, "DELETE" the old record and then "INSERT" if it does.
