Guide to using LVcompare with ClearCase
Hi all,
I have got the LabVIEW LVCompare.exe working with ClearCase on windows.
This means that you can do LV differencing using the source control integration with LabVIEW or from the ClearCase explore or the tree view.
Would anybody be interested in a step by step guide on how to do this ?
For those in the know you just need to edit the ClearCase map file ( C:\Program Files\Rational\ClearCase\lib\mgrs\map ) and change the compare & xcompare type managers for the correct file type.
z_whole_copy		compare				..\..\bin\cleardiff.exez_whole_copy		xcompare			..\..\bin\cleardiffmrg.exechange to z_whole_copy            compare                     	..\..\..\..\NATION~1\Shared\LABVIE~4\LVCompare.exe z_whole_copy            xcompare                        ..\..\..\..\NATION~1\Shared\LABVIE~4\LVCompare.exe
but as I said if anybody was interested I could do a step by step guide.
Danny
Good info,
could you create a page on the LabVIEW wiki, have a look at the Mercurial page for an example.
Ton
Hi Ton,
Thank you for pointing my that way.
I have created a new entry on the Wiki ClearCase and have put in there more details on how to set this up. I will try and over time fill in some more of the heading I have created to make it a more full and worthwhile entry. I hope people forgive my spelling.
I am not confident on the categories in the wiki but it would be nice for the Set up differencing capabilities page to actually go to a page with links to settingup subversion, setting up Mercurial, setting up ClearCase etc. rather than just go to the subversion one
cheers
Dannyt
PS you can use spaces in the map file mentioned about so use
z_whole_copy compare ..\..\..\..\National Instruments\Shared\LabVIEW Compare\LVCompare.exe
z_whole_copy xcompare ..\..\..\..\National Instruments\Shared\LabVIEW Compare\LVCompare.exe
rather than
z_whole_copy compare ..\..\..\..\NATION~1\Shared\LA9418~1\LVMerge.exe
z_whole_copy xcompare ..\..\..\..\NATION~1\Shared\LA9418~1\LVMerge.exe
Edited by dannyt
  • 5 months later...
A small update, if you want to be able to use the possible command line switches, with the LVCompare.exe and ClearCase you will need to use some form of wrapper to allow you to select the switch options and add them to the ClearCase passed in args and pass then onto LVCopmare.
Here is a simple version, written in LabVIEW 2010.
When you do a ClearCase difference it will launch the pop up below allow you to select the compare options then launch the compare
post-7256-0-70801400-1305622134_thumb.jp
The Zip file contains the files
go_compare.vi
Go-Compare.exe
Install NOTES.txt
To install
1) Copy the executable to the dir
C:\Program Files\National Instruments\Shared\LabVIEW Compare\
2) Edit the Clearcase map file
C:\Program Files\Rational\ClearCase\lib\mgrs\map make a copy first :-)
the lines for the z_whole_copy compare & xcompare should be changed
from
to
z_whole_copy compare ..\..\..\..\National Instruments\Shared\LabVIEW Compare\Go-Compare.exe
z_whole_copy xcompare ..\..\..\..\National Instruments\Shared\LabVIEW Compare\Go-Compare.exe
if you only want the default LVCompare without the wrapper to change compare options use
z_whole_copy compare ..\..\..\..\National Instruments\Shared\LabVIEW Compare\LVcompare.exe
z_whole_copy xcompare ..\..\..\..\National Instruments\Shared\LabVIEW Compare\LVcompare.exe
Hope some people find this useful
go_compare.zip
