Michael ten Den Posted December 15, 2010 Report Posted December 15, 2010 I was busy to program a program that reads from UDP CAN messages. When I hitted the run button, LabVIEW crashed. I had the error: "LabVIEW 10.0 Development System werkt niet meer" (English: "LabVIEW 10.0 Development System doesn't work anymore".) LabVIEW 10 coudn't find a solution for this, so it quitted. I restarted LabVIEW and opened my VI and the same error occurred. I can still open everything and my project in LabVIEW, but not my VI. I tried on another PC and it still doesn't work. Luckely I have backup, but how to avoid for a next time this problem. Has somebody experience with this problem? *Sorry if I putted this topic in wrong section. ____________ Michael ten Den Quote
SuperS_5 Posted December 15, 2010 Report Posted December 15, 2010 Hi, I am only guessing, but, there may be a driver problem. (Some dll call is doing bad things.) If you can reliably recreate the error, I would duplicate your project, and start stripping out everything bit by bit, only stopping when there is no problem anymore. This would allow you to isolate the problem, and probably have enough missing that you could even post it here. Quote
Michael ten Den Posted December 15, 2010 Author Report Posted December 15, 2010 On 12/15/2010 at 6:49 PM, SuperS_5 said: Hi, I am only guessing, but, there may be a driver problem. (Some dll call is doing bad things.) If you can reliably recreate the error, I would duplicate your project, and start stripping out everything bit by bit, only stopping when there is no problem anymore. This would allow you to isolate the problem, and probably have enough missing that you could even post it here. You mean that it can be a problem in one of my subVI's? Because my main program, where the error occured, no longer works and opens. ____________ Michael ten Den Quote
SuperS_5 Posted December 16, 2010 Report Posted December 16, 2010 On 12/15/2010 at 7:21 PM, Michael ten Den said: You mean that it can be a problem in one of my subVI's? Because my main program, where the error occured, no longer works and opens. ____________ Michael ten Den That would be why you would want to try to isolate the offending code. "Something not working" is hard to debug, "This thing is not working" is usually fixable. Quote
Rolf Kalbermatter Posted December 16, 2010 Report Posted December 16, 2010 On 12/15/2010 at 7:21 PM, Michael ten Den said: You mean that it can be a problem in one of my subVI's? Because my main program, where the error occured, no longer works and opens. ____________ Michael ten Den If the VI already crashes when it is opened then something has been corrupted. It could be one of the subVIs it uses or the actual VI itself. Corruptions while not very common do happen and the only way to deal with them is by backing up your work regularly. If the VI crashes as soon as you start it, then it may be calling some invalid method, or into a driver which has gotten corrupted. In the driver case reinstalling the driver software might help. Quote
Michael ten Den Posted December 16, 2010 Author Report Posted December 16, 2010 Thank you rolfk, The VI already crashes when it is opened. I store all my SubVI's in a project. So I expect it would not be a incorrupted subVI, but I don't know that. So I'm going to try some stuff with it. Lucky I had a backup. But from 2 days earlier. This problem shows that you can do a lot in 2 days On 12/16/2010 at 8:37 AM, rolfk said: If the VI already crashes when it is opened then something has been corrupted. It could be one of the subVIs it uses or the actual VI itself. Corruptions while not very common do happen and the only way to deal with them is by backing up your work regularly. If the VI crashes as soon as you start it, then it may be calling some invalid method, or into a driver which has gotten corrupted. In the driver case reinstalling the driver software might help. Quote
SuperS_5 Posted December 17, 2010 Report Posted December 17, 2010 (edited) On 12/16/2010 at 5:53 PM, Michael ten Den said: But from 2 days earlier. This problem shows that you can do a lot in 2 days Some kinda of source control is usefull there. I use SVN, but, it is not the only solution. Commit often, and you don't have to worry about zip files, and which version is which. Even with one developer and one computer, it is worth the effort to learn. PS. A corrupted VI is what caused me to take the jump to source control. Saved me, many times over. Edited December 17, 2010 by SuperS_5 Quote
