Get File path when opening saved data
Hi everybody,
I'm acquiring data and saving that on my disk as .dat.
Now I want to later open and analyse the data.
So I'm busy with writing a VI thats read the .dat file. The VI is going to be a .exe file.
This results in that I can set all my .dat files to that executable.
The problem is:
When I run my .exe, it still want me to select the .dat file I want to open.
But I want it to read the path of the .dat file i'm opening
Hopes my problem is clear ;)
____________
Michael ten Den
Hi everybody,
The problem is:
____________
Michael ten Den
If you mean you want it to remember a fixed location. then you will have to either save the path somewhere (and load it when tha app starts), hard-wire a path into the file open, or save a control as a default value (right click on control then select "Data operations>>Make Current Value Default")..
The reason it is asking you is because you have not specified a path into the file open (bear in mind that controls are reset to defaults when you open a vI or exe for the first time).
Thanks for your respons, only thats not exactly what I ment.
I want the executable to get the path of the .dat file and open it.
Hi everybody,
The problem is:
____________
Michael ten Den
Do you want the application that you have written to load when you double click the *.dat file, and directly start processing the clicked *.dat file?
If this is what you want, please checkout the link
http://labviewwiki.o...indows_Explorer
/J
