MOM Posted January 1, 2011 Report Posted January 1, 2011 Hi to all I have assessment in Water pump system I have a problem in the partial and only one I Want someone help to solution of these am the problem A water flow sensor is used to measure the water flow rate inside the drain pipe. There are two functions of the water flow sensor, while the pump is ON it checks that there is a water flow, but while the pump is OFF (or disable) it also checks that the water has stopped. Thus later check is used as confirmation that the pump has indeed been stopped. If the water flow becomes zero and the pump in the ON state then the pump must be directly and automatically turned OFF to avoid any damage in the system and water flow alarm must be ON to indicate that there is a problem in the drain pipe system Quote
SuperS_5 Posted January 2, 2011 Report Posted January 2, 2011 (edited) Hi, Do you have any thing done yet? Do you have a LabVIEW related problem that we can help with, or do you want us to do your work for you? I am not trying to be mean, but you have not posted anything about any solution that you have generated yourself. This seams like a generic use case for a simple state machine. There are many resources available to help with the architecture concepts if you need it. (There are also resources to help with LabVIEW programming too.) Edited January 2, 2011 by SuperS_5 Quote
Roderic Posted January 5, 2011 Report Posted January 5, 2011 Agree with supers_5 you just need a simple state machine architecture, what is your problem exactly? because it seems pretty simple (I may be wrong) Quote
Roderic Posted January 5, 2011 Report Posted January 5, 2011 I wrote some code for you as I had a few minutes to spare. I quicly tested it and it meets your requirements. I suggest you test it and add the required code to control your pump. Main state machine lava.vi Commande 1.ctl Quote
SuperS_5 Posted January 7, 2011 Report Posted January 7, 2011 The execution seams a little weird to me, but it still shows the basic state machine in action. Kudos. Quote
