754840824 Posted January 2, 2011 Report Share Posted January 2, 2011 I'm using LabVIEW 8.6,and I have got images from one USB camera .Now I want to get 2 usb cameras ,how can I do ? Does 8.6 can meet this function ? thanks ! Quote Link to comment
SuperS_5 Posted January 2, 2011 Report Share Posted January 2, 2011 Could you post your example code. If you are using IMAQ, this is fairly easy. Quote Link to comment
SuperS_5 Posted January 2, 2011 Report Share Posted January 2, 2011 (edited) Here is an example. It took a while to get my second cam working with this new laptop to test it out. For some reason I couldn't make this a code snippet, but all well, here is just the pic. Edit: I used one loop here for simplicity, you could have them in totally separate loops if needed. You could also call them sequentially. Edited January 2, 2011 by SuperS_5 Quote Link to comment
tushar Posted February 4, 2011 Report Share Posted February 4, 2011 just in case you don't need vision development module. then you can see this http://www.fathsoft.com/videocapx.html i have used this at one of our clients for capturing images from 4 cameras and we found it excellent also if you are using NI IMAQ USB then version does matter, previous versions of it does not support capturing from two cameras if they have identical name(i.e. two cameras of exactly same brand&model) Quote Link to comment
