High Temperature Air Velocity measurement
Hi All
I am hoping someone here has some ideas for me on this one , I need to measure velocity of gas (in this case air) through a pipe , that's easy enough , however , the temperature of the gas ranges from 100C to about 1200C and from maybe 10 m/s up to ~120 m/s.
Any Ideas ?
Dan
  On 1/20/2011 at 5:46 PM, Dan Bookwalter N8DCJ said:
Hi All
Any Ideas ?
Dan
No source but the ultrasoic flow meters use the speed of sound running forward and backwards and the difference tells the speed of the medium ( the gas).
Ben
I don't know if it will work for you, but I had good luck using a McCrometer V-Cone flow meter a few years ago. Give them a call and see if they can size one for you. You'll also need a differential pressure transducer and some math to get a good measurement.
