Get Cluster Items programmatically
Hi, I try to get cluster entries programmatically, but I can`t cast to datatype
post-18294-0-53216200-1300353028_thumb.p
Edited by zlocm
Hi
As your two outputs are arrays I am assuming your cluster has two arrays in it. If that is the case you are trying to cast an array into a digital type you missed out the array cast see below
post-7256-0-04373900-1300355865_thumb.pn
A couple of things to look at to learn more about this control reference casting that might be of interest
Wiki control ref & control ref nugget & Try multiple type casts
hope this helps
Dannyt
This may be too trivial of an answer for your application, but you can just right click on a cluster element, select Create-> Reference, and a reference to the cluster element appears on your BD. No casting necessary.
