Sarah83 Posted September 3, 2004 Report Posted September 3, 2004 Hi, is there a function to set numeric elements blank like for stings the blank string constant? Quote
Paulo Almeida Posted September 3, 2004 Report Posted September 3, 2004 Sarah83 said: Hi, is there a function to set numeric elements blank like for stings the blank string constant? 1628[/snapback] Hi, You can't put numeric elements blank, only zero, NaN or INf, but these two i don't know how to put. Sometimes my numeric elements change to NaN and i don't know know has was happened. You can create a Local variable for your numeric elements and change this local variable to write. and put one zero in this local variable or you can convert the numeric element to a string put this string blank and convert the string to numeric element :!: Quote
Sarah83 Posted September 3, 2004 Author Report Posted September 3, 2004 Paulo Almeida said: Hi, You can't put numeric elements blank, only zero, NaN or INf, but these two i don't know how to put. Sometimes my numeric elements change to NaN and i don't know know has was happened. You can create a Local variable for your numeric elements and change this local variable to write. and put one zero in this local variable or you can convert the numeric element to a string put this string blank and convert the string to numeric element :!: 1629[/snapback] Oh, you're right :thumbup: I choosed the local variable zero Quote
didierj Posted September 3, 2004 Report Posted September 3, 2004 Quote You can't put numeric elements blank, only zero, NaN or INf, but these two i don't know how to put. Sometimes my numeric elements change to NaN and i don't know know has was happened. If you use SGL, DBL or EXT you can set these "Values" just by typing NaN or Inf into the control or constant. For integer values they are meaningless. Didier Quote
