Join - Split Question
Hi!
I've attached a vi, and an Image. I would like to send this image from RT to FPGA with DMA FIFO. In order to reduce the transfer time, I've joined U8 values to U64. After rebuilding my Image, I've seen, there is an unexpected shift on the reconstructed Image.
Could you give me some explanation about this?
Test.zip
Edited by durnek60
The logic on the first for loop looks a bit strange to me. Changing it slightly solves your problem.
post-17903-0-11032900-1303954868_thumb.p
I found 2 more solutions:
These being closer to your original code.
post-17903-0-56505900-1303955311_thumb.p
Edited by SuperS_5
Thank you very very much! :)
