Jon Sjöstedt Posted May 3, 2011 Report Posted May 3, 2011 Hello! I need to create a pattern that is made up from four digital outputs which are pulsed at well defined timeings. I have borrowed a NI USB 6341 and done some tests. Unfortunately the documentation is very poor, and leavs most real technical questions unanswered. I would like to create something like this: * Ctr0-Ctr2 are driven by 100MHz timebase * Configure Ctr0-Ctr2 to generate a trig-start for port0.0-port0.2 after different delays * Output data at port0.0-port0.2 when Ctr0-Ctr2 trigs them * Output from port0.0-port0.2 are made up from two samples (HL) and timed by something else than the 100MHz timebase Is that possible? I use LV2010 on Windows If there exists a real technical reference for the USB 6341 that someone can point out, I would like to read it. 370784c.pdf is the best i've got so far and it is in no way complete IMO. Quote
Tim_S Posted May 3, 2011 Report Posted May 3, 2011 I would like to create something like this: * Ctr0-Ctr2 are driven by 100MHz timebase * Configure Ctr0-Ctr2 to generate a trig-start for port0.0-port0.2 after different delays * Output data at port0.0-port0.2 when Ctr0-Ctr2 trigs them * Output from port0.0-port0.2 are made up from two samples (HL) and timed by something else than the 100MHz timebase I believe the coding reference you are looking for exists with in the LabVIEW examples. The whole solution will not be there, but pieces will be. I think what you've listed is possible, though I'm not entirely clear on what you're doing. You can route signals internally to generate trigger signals, however this is a 1-to-1 mapping. You would have to OR the signals together externally and route the result back in to do what you describe. Tim Quote
Jon Sjöstedt Posted May 17, 2011 Author Report Posted May 17, 2011 Hello! Thanks for the examples-tip. I have gone through a large set of DAQmx-examples and now I have a much better idea on how to aproach my problem. New question is (the initial problem is altered a bit to simplify the requirements for the IO-box): I want to create a task that is triggered by /dev/do/StartTrigger, but I cant see how to select which internal terminal to connect with the do/StartTrigger. MAX contains a map on which connections are possible, but I cant see how to use that to configure a connection or how to do it in LabVIEW. I want to do it in LabVIEW.Any ideas? Quote
