How to reset a Start button?
Hello,
I have a "start button" that is connected in a True/False case Structure (See attached picture). When the button is pressed it sends a "True" signal and the timer inside the case structure counts to 30". When the 30" is reached the structure gives a "True" signal out for the program to stop.
The problem is that when I start the program again, the "start button" will start at the pressed position. How can I make the "start button" to always start at the unpressed position?
Thank you in advance,
post-20867-0-19507500-1305037422_thumb.j
The simplest method is to create a local variable (Right mouse button on the control --> Create --> local variable). Either wire it off your true statement (add the negate), or put a false constant inside the loop and wire it to the local variable outside it.
Hope this helps
Set your boolean value to default at False and call the method "Default Values >> Reinitialize All to Default" when you start your program.
This method has the benefit of reinitializing all your controls/indicators to their default value with one call.
post-10515-0-02558900-1305039300_thumb.p
Have you considered just using a latched boolean? Boolean controls that are "latched" reset themselves to the default value after they are read once on the diagram.
  • 1 month later...
