How to reset a Start button?
Hello,
I have a "start button" that is connected in a True/False case Structure (See attached picture). When the button is pressed it sends a "True" signal and the timer inside the case structure counts to 30". When the 30" is reached the structure gives a "True" signal out for the program to stop.
The problem is that when I start the program again, the "start button" will start at the pressed position. How can I make the "start button" to always start at the unpressed position?
Thank you in advance,
post-20867-0-19507500-1305037422_thumb.j
The simplest method is to create a local variable (Right mouse button on the control --> Create --> local variable). Either wire it off your true statement (add the negate), or put a false constant inside the loop and wire it to the local variable outside it.
Hope this helps
  • 1 month later...
