george seifert Posted May 31, 2011 Report Posted May 31, 2011 In LV2010 the color history isn't kept when LV is exited - at least on my PC. Is there a new setting that I'm missing that allows the history to be kept? George Quote
Yair Posted May 31, 2011 Report Posted May 31, 2011 I'm assuming the color history is kept in the INI file. Maybe you don't have write permissions to the LV folder? It should be fairly easy to check by changing a setting which is written to the INI file. Quote
george seifert Posted June 2, 2011 Author Report Posted June 2, 2011 On 5/31/2011 at 4:10 PM, Yair said: I'm assuming the color history is kept in the INI file. Maybe you don't have write permissions to the LV folder? It should be fairly easy to check by changing a setting which is written to the INI file. I've always had permissions in the past on older versions of LV. Plus I'm an administrator on this PC so I can't see why I wouldn't have permission. George Quote
Mr Mike Posted June 2, 2011 Report Posted June 2, 2011 On 6/2/2011 at 1:10 PM, george seifert said: I've always had permissions in the past on older versions of LV. Plus I'm an administrator on this PC so I can't see why I wouldn't have permission. George I never noticed it kept that between runs! It works for me on 2010. The INI tokens are colorHistoryItemA through colorHistoryItemK. Do you see those in your INI file / do they change when you pick colors and close LabVIEW? I think when you select a color, that color gets put in K and then everything from K to B shifts to J to A. Quote
