Press to Spin mechanical structure?
My boss needs me to create/find an object which converts compression force into rotational torque.
The object needs to be cylinder shape with max 1.5 cm height and 5 cm diameter. The max compress distance is 0.5cm.
Does anything like that in market?
A pinion gear meets that criteria. Combined with a rack.
http://www.sdp-si.com/eStore/CoverPg/Gears.htm
Ben
  • 3 weeks later...
