Staffan Posted June 13, 2011 Report Share Posted June 13, 2011 I am building an exe using LV 2010 SP1. The project contains about 6000 files (Vis, classes and lvlibs) After several hours I'm getting Build unsuccesful/Error 1 "Invalid input parameter...at xxx.vi". If I restart the buildingprocees I get the same error but on a different vi. None of the the vis are broken. Everything was ok until I added a set of new classes(plugin style). If I remove some other classes the build is ok, so it is not directly related to the new classes. Anyone experienced the same problem? /Staffan Quote Link to comment
Neville D Posted June 20, 2011 Report Share Posted June 20, 2011 Have you tried a mass compile of the entire project? Quote Link to comment
Staffan Posted August 30, 2011 Author Report Share Posted August 30, 2011 Mass compile did not help. I have been struggling with this problem for quite some time. NI made a fix to solve the problem which will be implemented in next LV2011 patch. /Staffan Quote Link to comment
