P3HT Posted September 15, 2004 Report Posted September 15, 2004 I am learning LV and need set up a system to get I-V curves from source meters. Could any one give me some suggestions about how to start it or share a VI with me? I appreciate you very much for your help and time. Quote
Paulo Almeida Posted September 15, 2004 Report Posted September 15, 2004 I am learning LV and need set up a system to get I-V curves from source meters. Could any one give me some suggestions about how to start it or share a VI with me? I appreciate you very much for your help and time. 1761[/snapback] Hi, the simply way to start work with LV is to see the Labview examples, there are most of things to need to start in this language Help -> Find examples regards Quote
P3HT Posted September 16, 2004 Author Report Posted September 16, 2004 Hi, the simply way to start work with LV is to see the Labview examples, there are most of things to need to start in this language Help -> Find examples regards 1762[/snapback] Hi, Thanks for your information. The examples is a little helpful. I still need more help. I would appreciate you if you could provide. Thanks again. Quote
todd Posted September 17, 2004 Report Posted September 17, 2004 Here's something for the Keithley 2400. Download File:post-107-1095458871.llb Quote
shahzaib198 Posted November 27, 2007 Report Posted November 27, 2007 Hi Well I want your help in few things: How to interface a hardware with VI Plz help me out in this topic and do also send me a example project like connecting LEDs through Parallel port and giving signal from it. Thanks ShahZaib Quote
LAVA 1.0 Content Posted November 27, 2007 Report Posted November 27, 2007 QUOTE(shahzaib198 @ Nov 26 2007, 03:11 AM) ... send me a example project like connecting LEDs through Parallel port and giving signal from it. I suggest the following: Try searching this site using the Search button connecting LEDs through Parallel port and giving signal from it If this is homework, you should be careful in hooking up anything to your computer's parallel port; you could damage the parallel interface or even the whole computer unless you know what you are doing. If this is for work or lab use that requires long term use or reliability, you should seriously consider an I/O device that is designed to interface to TTL logic and classic analog signals like this, this or this. Quote
