Paulo Almeida Posted September 22, 2004 Report Posted September 22, 2004 I'm using a text ring to control one case structure and i want disable one of his items using a Property node but i don't find any property for disable only one item. Anybody knows some property to do that. I run all properties and don't find :headbang: Quote
Jimmy-Chen Posted September 22, 2004 Report Posted September 22, 2004 You can use the property Node>>Disabled Items[] to disable items. Download File:post-705-1095859167.bmp Quote
Paulo Almeida Posted September 22, 2004 Author Report Posted September 22, 2004 You can use the property Node>>Disabled Items[] to disable items.Download File:post-705-1095859167.bmp 1875[/snapback] Thanks Jimmy-Chen It's work i'm so dah :headbang: i don't see that regards Quote
