sjukheter Posted August 29, 2011 Report Posted August 29, 2011 Hi, i am thinking to do in labview for our production controlling. I have some pupms that can generate noise when stroke touches the inside mechanical parts. I am adjusting this noise by adjusting the stroke length manuvally in soft ware and then they prepared for selling. But, why not i can make a automated system that can calibrate these noise. SO, i think i can take some sound sensor which can handle 50db- 120 db sound. and the sound in 50-70db means no noise, if i hit other range then its noise by touching mechanical part. i think i can get the data from sound sensor to labview and make the adjustment automatically. Here i have some questions? 1) choosing sound senor and can it differenciate two sounds? please give me some sound sensors if someone know. Note: i would like to use sensor as externally. 2) If i am write with above, how can i get data to labview from sensor? I searched a lot on web for sound sensors but can't able to get one as my requirement. Even, i can use pressure or vibration sensors. Please some one suggest me. Quote
Wire Warrior Posted August 29, 2011 Report Posted August 29, 2011 You might try your NI sales rep. They can sometimes have suggestions in situations like this. Jason Quote
Saverio Posted August 29, 2011 Report Posted August 29, 2011 For those responding: this was also posted on the NI site here: http://forums.ni.com/t5/LabVIEW/is-it-possible-in-Labview-Suggest-me/td-p/1686440 If responding you may wish to review what has already been said there so as not to repeat suggestions. Quote
