Roderic Posted September 28, 2011 Report Share Posted September 28, 2011 Hi all, I'm just starting preparing for the CLD exam and I'd like to get some feedback on my coding style. I think my documentation is weak, and I have some functionality issues (slides doesn't seem to work so I added a digital display I dunno what I've done wrong).I did not used tip strips for FP objects as it seems like they removed it from the exam requirements. I found the time limit to be tight (maybe I'll get 15 extra minutes with the new format as I don't need to make the front panel) Can you please rate my code? Best regards, Rodéric Boiler Controler.zip Quote Link to comment
Roderic Posted September 29, 2011 Author Report Share Posted September 29, 2011 (edited) Neil thanks for the input, I'll try to make it more neat, meaning I really need to code faster. To answer your question: I don't know, this seemed to be the right thing to do as I get the value at the moment the value changes (in case I have multiple states in the FIFO), but I think your method is simpler and maybe the best way to handle this (and it's simpler/faster). thanks. Do you think I would pass with a bit more practice or there are some major improvements needed? Edited September 29, 2011 by Roderic Quote Link to comment
