bulebell Posted September 29, 2011 Report Posted September 29, 2011 (edited) when i use this vi to read a txt file, the file is too big,and it overflow. in the diaplay window,it just show a little of the file. how can l handle with this problem? should i set a buff to solve it? Edited September 29, 2011 by bulebell Quote
BigAngryHillMan Posted September 29, 2011 Report Posted September 29, 2011 Can you post a example of your code and the text file you are trying to read, or a least the size of the file. Quote
bulebell Posted September 30, 2011 Author Report Posted September 30, 2011 I don't konw how to attach my vi. Quote
BigAngryHillMan Posted September 30, 2011 Report Posted September 30, 2011 Press the "More Reply Options" button to attach your file. Quote
Cat Posted September 30, 2011 Report Posted September 30, 2011 Is "Read from Text File" actually throwing an error? If so, what error is it reporting? How big is the file? If not, (sorry if this is obvious) I assume you know you can expand the "text" indicator coming out of "Read from Text File" and right-click on it to make a vertical scrollbar visible? This will allow you to see all the text. Quote
