aledain Posted October 7, 2004 Report Posted October 7, 2004 I have a need to make a VI extremenly thin (a special dialog). When I try and resize the VI in the edit environment it does not go thinner than a certain width. Do I need to do this programmatically or is there a way to remove this limitation? 6.02 code only please :headbang: Quote
PJM_labview Posted October 7, 2004 Report Posted October 7, 2004 I have a need to make a VI extremenly thin (a special dialog). When I try and resize the VI in the edit environment it does not go thinner than a certain width. Do I need to do this programmatically or is there a way to remove this limitation? 6.02 code only please :headbang: 2144[/snapback] Alex This is true, in edit mode you can not get as small as you want, but programmatically you can get very small. I had VI getting as small as 4x4 (this is 4 pixel by 4 pixel). I had not done this in 6.02, but I dont see why it should not work. PJM Quote
FLX Posted October 7, 2004 Report Posted October 7, 2004 I have only LV7.0, too. but here an image how it works with VI server. Quote
