lvb Posted November 11, 2011 Report Posted November 11, 2011 To use a USB Bluetooth device in LabVIEW, the device must use the Windows Bluetooth stack. Does anyone know of an instrument driver for the Toshiba Bluetooth Stack? Quote
ShaunR Posted November 11, 2011 Report Posted November 11, 2011 the device must use the Windows Bluetooth stack. That's funny. I'm using the Widcomm one. Quote
lvb Posted November 11, 2011 Author Report Posted November 11, 2011 That's funny. I'm using the Widcomm one. With the native LabVIEW functions? According to How Do I Make a Bluetooth Device Work with LabVIEW? only the Microsoft stack can be used. Are you calling a DLL library? Quote
asbo Posted November 11, 2011 Report Posted November 11, 2011 I spent a lot of time trying to use Bluetooth functions from LabVIEW. My solution was not to use the built-in nodes, but to use CLNs to call the Windows API to accomplish functionality. Some functions are difficult to integrate because in a couple instances direct C-to-LabVIEW ported code would behavior differently. For some of my functionality, I ended up relying on a System Exec call to the compiled C code because I couldn't make LabVIEW behave. What functionality are you looking for? Quote
lvb Posted November 11, 2011 Author Report Posted November 11, 2011 I spent a lot of time trying to use Bluetooth functions from LabVIEW. My solution was not to use the built-in nodes, but to use CLNs to call the Windows API to accomplish functionality. What functionality are you looking for? More stability than a Microsoft driver. Quote
ShaunR Posted November 11, 2011 Report Posted November 11, 2011 No direct calls to a dll. I use this http://lavag.org/files/file/146-opp-push-file/ with the widcomm. If you are having difficulties, then you could try this http://bluetoothinstaller.com/ 1 Quote
