Ano Ano Posted November 17, 2011 Report Share Posted November 17, 2011 Hello, In the front panel I have indicators, buttons and text labels on a rectangular decoration (see attached picture). When I try to move these (buttons, indicators, text labels) on to a new rectangular decoration, they hide behind it! Why is this happening and how can I prevent/correct it? Thank you in advance, Quote Link to comment
Yair Posted November 17, 2011 Report Share Posted November 17, 2011 Your image wasn't attached, but in general, the Z-order of front panel objects is controlled by the reorder button: So just select the decoration and then move it all the way to the back. 1 Quote Link to comment
asbo Posted November 17, 2011 Report Share Posted November 17, 2011 So just select the decoration and then move it all the way to the back. The shortcut for All The Way To The Back is Ctrl+Shift+J. All The Way To The Front is Ctrl+Shift+K. I use these often. Be mindful of when you have controls/indicators/decorations mixed with containers (like a tab control), since the Z-Order instead the tab control is completely separate from the Z-Order of the FP. Quote Link to comment
Yair Posted November 17, 2011 Report Share Posted November 17, 2011 Actually, those are move one. Move all the way require Shift as well. Quote Link to comment
asbo Posted November 17, 2011 Report Share Posted November 17, 2011 Actually, those are move one. Move all the way require Shift as well. The funny thing is I went and tested it to be sure I didn't have the two switched, used Shift with the key combinations, and then wrote it down wrong. Thanks for catching that. Quote Link to comment
