Tim_S Posted December 13, 2011 Report Posted December 13, 2011 I ran into a bug in LV 2011 with the List Folder primitive. A pattern with an underscore in it will return an empty array despite matches in the target directory. Here is a demonstration of the bug: List Folder.zip I contacted NI about the bug. There is a CAR for the MAC OS only at the moment and it will either be updated or a new CAR created. I wasn't able to get what version of LabVIEW will correct this. Tim 1 Quote
Saverio Posted December 14, 2011 Report Posted December 14, 2011 Ummm... slight problem with example... the value for the item "Test123_*.* (doesn't work)" is actually defined as "Test_*.*". No files in the test directory match that pattern, irrespective of the List Folder function. If I place a string control on the front panel and enter a pattern of "Test123_*.*" then the resultant array is ["test123_1.txt", "test123_2.txt"]. Quote
Tim_S Posted December 14, 2011 Author Report Posted December 14, 2011 Gah! Okay, that's a little embarrassing. I thought I had a sample of what was causing the issue I was seeing in my actual code. Okay, back to head scratching on the bug in my code. Quote
