Line Graph in LabVIEW with Repeating X Values
JohnLV
Hi Everyone,
Season Greetings to you all...
I am trying to create a Line Graph in LabVIEW that will plot with repeating X values.
Basically, my data looks like
X Y
0 1
1 4
2 2
3 43
4 43.5
5 55.9
6 68.3
7 80.7
8 93.1
9 105.5
10 8
0 7
1 5
2 3
3 1
4 -1
5 -3
6 -5
7 -7
8 -9
9 -11
10 -13
The Waveform Graph/ Chart will display the Y axis correctly, so the user gets the shape, but the X axis is just in numerical order which is not desired.
If i use the XY graph, the line turns back on itself because the X Values is repeating...
I have tried the X Scale marker values property node, but it did not display correctly.
Sorting X Values is not an option for my problem.
I have attached a Excel Sheet and a VI (LabVIEW 8.2) for your reference.
Thanks and Regards
John
XY Graph.zip
What is your question? If it is the line drawn back from (10 8) back to (0 7) that you don't want, then adding an extra point with a Y value of "NaN" (Not a Number) between them will eliminate the line.
Based on your excel file, you want a graph like the bottom one in the attached image, but with more ticks on the x-axis (... 8, 9, 10, 0, 1, 2, ...).
Apparently, you still have to use a workaround. See the non-trivial ideas in the links from Erik's comment in this idea:
http://forums.ni.com...es/idi-p/921601
  • 1 month later...
