Jon Kokott Posted January 11, 2012 Report Posted January 11, 2012 If I build a packed library with a class which is a descendant of another class, it is breaking the relationship of the child to the parent. Do packed libraries only support hierarchies that are fully enclosed in the packed library? Quote
Norm Kirchner Posted January 12, 2012 Report Posted January 12, 2012 I can't answer your question specifically, but there is a great deal of knowledge on classes, inheritance and packed libraries contained here. I would give a 68% chance you'll find your answer in there Plug-in design using LVLIBP https://decibel.ni.com/content/docs/DOC-19176 Good Luck ~Norm 1 Quote
Jon Kokott Posted January 12, 2012 Author Report Posted January 12, 2012 This is exactly what I'm trying to do, thank you. What a hack job that is, I never would have thought to delete the Parent library in the child build. Thanks again, I'll try it this weekend sometime. Quote
0_o Posted January 13, 2012 Report Posted January 13, 2012 I tried it too and unless we both didn't follow the instructions correctly then I guess it's not our fault. I even opened a call to NI support thinking it should have worked according to the PDF in 2010 and for some reason it stopped working in 2011. Yet, I just saw that it got updated two month ago to 2011 with a change that deals specifically with dependencies so I'll go over it one more time and report. Quote
Jon Kokott Posted January 23, 2012 Author Report Posted January 23, 2012 Everything works as described in the link. Thanks again. Quote
