How do I programmatically end a process in windows
We are running a test on a circuit board. In order to test the unit we are required to use a .dll that the client wrote. The problem is if the board is bad the .dll hangs. Because the board is a security device we are not allowed to mess with the dll in any way and the source code is not available. The only way to fix the problem right now is to go into task manager and end the process.
Does any one have code that will do this programmatically or know what the API call would be
2429[/snapback]
Here are some VIs that use system exec to execute the tasklist and taskkill commands.
Download File:post-17-1098386155.zip
-Jim
Jim, I had wrote some functions, using .NET framework, this will work with 7.0 and up.. Code is at home, so I cannot post it right now.. If there is someone interested, I will post tomorrow..
This including:
functions : PIDs by names, names by PIDs, kills, CloseWindows, how many threads, memory counts, processor "busy" couns, child windows counts..
look at system.dll in .NET framework.
Besides, you could use pskill.exe from sysinternals.. You can kill by name there. This is easyest way..
/ProximaBleu
  • 8 months later...
we have some old applications written in LabView 5.1. And now we want to broaden this applications with some features including this tasklist.
so how can i use this functions in lv5.1?
  • 1 month later...
Also just for a bit of information. The Taskkill and Tasklist commands only work in Windows XP. In Windows 2000, I think the command would only be "kill" and not "taskkill". I'm not sure if there is an equivelent for tasklist.
I may be wrong, but I'm pretty sure this is the case.
