Make waveform chart A look similar to chart B
I have got a waveform chart which I am trying to design myself. It looks very simple so I tried to design it. I have added in the attached vi both waveforms. The Waveform A is the one which I would like to look like Waveform Chart B. Any ideas?
Kind Regards
Austin
Customizing waveform chart.vi
Select the paintbrush tool from the tool palette, right click on the gray area of Waveform A, then select the T in the top right corner in the color palette which appears. You can left-click the plot list to apply the same color.
Right-click the scale, select Duplicate Scale. Right-click the new scale, select Swap Sides.
The rest should be easy through the properties dialog.
