sirzrx Posted November 13, 2004 Report Posted November 13, 2004 INPUTS = h and p OUTPUT = a ill use this syntax to move across a long constant array table. this is a Formula Node like C++ Programing ---------- if(h=40) { a=1; } if(h=50) { a=9; } if(h=60) { a=13; } if(h=75) { a=17; } a=a-p; ------- WHY THE OUTPUT IS ALWAYS THE LAST a VALUE? should i use switch-case if i have... can some post an example?.....Thx for ur help! ------------------------------------- By Sir ZRX! Quote
jpdrolet Posted November 14, 2004 Report Posted November 14, 2004 INPUTS = h and pOUTPUT = a ill use this syntax to move across a long constant array table. this is a Formula Node like C++ Programing ---------- if(h=40) { a=1; } if(h=50) { a=9; } if(h=60) { a=13; } if(h=75) { a=17; } a=a-p; ------- WHY THE OUTPUT IS ALWAYS THE LAST a VALUE? should i use switch-case if i have... can some post an example?.....Thx for ur help! ------------------------------------- By Sir ZRX! 2641[/snapback] The correct syntax to test an equality is if (h==75) . As written, if (h=75) assigns 75 to h and tests its value to TRUE, since it is different from 0. Quote
sirzrx Posted November 22, 2004 Author Report Posted November 22, 2004 THX is working right now thx ^^ Quote
