Simple question tab-order between controls and within cluster controls
I guess a fairly simple question but for and my customer important issue.
What determines which control that are visited next when a user use tab to move to next control?
You can specify the tabbing order from the Edit menu -> Set Tabbing Order..., at least in LabVIEW 2011.
I think I recall that this was named something like "Set Frontpanel order" in earlier LabVIEW versions, but I cannot check right now.
/J
Thanks Mellroth.
I tested this but very strangely only on graph and two button control was possible to change the order on. I have two numerics and two string controls and on these it seems impossible change the tabbing order (which goes from the last to the second..). All these are on tab-control.
Has any of you experienced to thing similar?
