mje Posted September 7, 2012 Report Posted September 7, 2012 Does LabVIEW have any capacity to resolve font types? That is say I want a text box to be monospace, or sans-serif, but really don't care what the exact font is. Is there a way for me to set this and just let the IDE figure out what the system defaults are? I'm pretty sure the answer is no, but lava often surprises me. Quote
Minh Pham Posted September 10, 2012 Report Posted September 10, 2012 I would query the system fonts and use the most common one for the controls/indicators. I found this which might helps systemfontsPlay.viUnavailable Quote
bmoyer Posted September 10, 2012 Report Posted September 10, 2012 Using systemfontsPlay.vi as a starting point I made a VI that will determine all of the fixed-width fonts. It's slow but it seems to work. For your application you could have 2 hidden indicators (one with "iii" and one with "www") set to the system font and see if they're the same size using the Label.Width property. Bruce Find Fixed-width Fonts.viUnavailable Quote
mje Posted September 10, 2012 Author Report Posted September 10, 2012 Hehe, I already poke around the registry to obtain a font list. I'm not sure I like the idea of testing individual fonts, not only is it slow, but it doesn't help if I want to distinguish serif from sans-serif, for example. Granted, for this application all I care about is monospace... Dug this up while poking about the MSDN: Windows specific, but seems to work. Quote
